fuse voltage for a 04 warrior?
Old Apr 24, 2006 | 05:34 PM
aznmx's Avatar
Default fuse voltage for a 04 warrior?
Hi I just got my 2004 Yamaha Warrior and it keeps blowing out the fuses. I just pulled out a 20 AMP and 32 Volt fuse. What kind of fuse should I put in? I'm only 14 so im kinda new at this. Thanks
Old Apr 24, 2006 | 05:41 PM
bberck's Avatar
Mine has a 15 amp fuse in it you better check for a bare wire or a bad ground some where
Old Apr 24, 2006 | 05:43 PM
aznmx's Avatar
thanks a lot ill go buy a few now i guess.. anyone else have any other suggestions?
Old Apr 24, 2006 | 07:37 PM
recon99's Avatar
You have a wire shorted out somewhere.
This isn't the cause of the problem, but I suggest you get a blade fuse holder and the proper size fuse (I don't remember if it's 15 or 20), and splice that in in place of the glass fuse holder. Glass fuses are harder to find, and these stock holders are notorious for causing bad connections or falling apart on the trail.
Joe454
Nov 20, 2020 01:19 PM
Gwolf228
Feb 18, 2017 01:36 AM
Lucas Bohanan
Sep 29, 2015 01:16 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
