Drain or not to drain? That is the question!
Sup guys my raptor has been sitting in the garage for about 8 months with 3/4 tank of gas. Should i drain it? Should I clean the carbs? I'm going to the shop tomarow to get a new battery and going to get her going. Anyone else use the old gas after its been sitting a long time?
I have engine mods but am kinda lazy and dont feel like listing them.
Take the gas cap off and smell the gas, allot of times the gas smells ransid when it goes bad. I would attempt to run it through and if it doesn't run good, then, clean the carb.
i have the same problem with my blaster. gas leaked from the carbs and i cant start it up anymore it takes like 15 mins and the engine revs high. i called my atv shop and they told me i have ot get the carbs cleaned..its like 300 dollers! i cant afford that. is there any other way i can solve this problem? thank you
I tend to be frugal with the time used working on the quad. If a can of fix it will clean the carb, then, it will save time. It also may perform a better job than trying to clean it by hand.
I have used BG 44K on several engines and it seems to work quite well.
