Whats the best exhaust i can buy for my raptor 660??
I have a 2003 raptor with an aluminum air box K&N airfilter, Edlebrock carb, (ported and polished head coming this winter) stage 2 hotcam, kibble white titanium valve springs, white brothers racing clutch, 15 tooth front sprocket(love high speeds), durablue rear axle, front a-arm kit, front & rear lowering kit and need a *&%$@#* awesome exhaust to cap it all off with. what company should i go with??? price range anything up to about 500$.
i was looking around this site a little bit and there seems to be a feud between raptors and 450's,not to mention a sort of underlying hatred towards raptors. Let me say right now that i will leave every single 450 in the dust. and im proud of it.
As for pipes it's a rather common topic and since you've been looking around you should have found the answer many times over.
Singles - CT, Sparks, Yoshi
Duals - LTE, Barker
Think what you may but i recently came into some money and completely worked my raptor which was slightly neglected for a few moneths while the starter was broken. but anyway worry about your self and settle all disputes in the trails. LOL
My 690 probably has right at 60 HP but that is just an educated guess.Larger bore size wont always give more speed.The 690 Raptors are usually the faster of the big bore Raptors when built properly.A 15 tooth front sprocket will give you mpre top end but you will lose a lot of low end grunt with that gearing.
