bogs on take off
Old Jun 6, 2006 | 07:16 PM
chddyddy's Avatar
Default bogs on take off
I have a raptor 350 and it bogs on take off for about 2-3 seconds, then its fine. the wierd thang is if I turn off the gas it runs better, then when its on. thanks for any help.
Old Jun 7, 2006 | 03:13 PM
GlennJ's Avatar
Sounds like it's running a bit rich. Have you done any jetting changes? You may want to inspect and clean the air filter.
Old Jun 7, 2006 | 09:26 PM
chddyddy's Avatar
i have a new air filter, the only thing that was done was, a high compression piston, and a webcam .430 with spring kit. i yesterday i took out the baffel (sp) and air lid off and it ran fine.
Old Jun 7, 2006 | 10:44 PM
GlennJ's Avatar
Have you rejetted after those mods?
Old Jun 8, 2006 | 12:23 AM
chddyddy's Avatar
i had a shop put in the piston, cam and spring. they didnt re-jet it. i thought it only need jetted if u put in a aftermarket filter, or put on a exhaust?
Old Jun 8, 2006 | 08:25 AM
GlennJ's Avatar
All those mods alter how much air and fuel the engine is sucking in. You'll without a doubt need to rejet with those mods.
Old Jun 8, 2006 | 02:42 PM
chddyddy's Avatar
i will have it jetted. is it hard? if its not i might try it. thanks alot
Old Jun 8, 2006 | 05:41 PM
GlennJ's Avatar
Not really. But are you comfortable with taking the carb apart a bit?
Old Jun 8, 2006 | 06:38 PM
chddyddy's Avatar
kinda, i have a book.
hueby
Nov 6, 2015 11:34 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
essonlaker
Sep 10, 2015 01:12 PM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
