Blaster Crankcase Leak???
Old Jun 20, 2006 | 10:55 PM
lildeezul's Avatar
Default Blaster Crankcase Leak???
u can get the splitting case tool at the yamaha dealer
Old Jun 20, 2006 | 11:03 PM
Boomer2's Avatar
It is probably as easy to split the case as it is to seperate the cases and squirt a sealant in. I used a harmonic balancer puller for a car to split the cases. It just a piece of metal with slots for bolts to attach to the crankcase. with a bolt in the center to push crank.
Old Jul 13, 2010 | 01:17 AM
sabin'satvrepair's Avatar
u dont need that take a shall hammer make sure all the case bolts are out thap that case softly with a hammer until u see the seam take two screw drivers and work the case apart its not hard to do and not like a honda where shims fall out all over the place all the gears etc have snap ring holding them on the shaft
Old Jul 13, 2010 | 01:20 AM
Default case splitting
also if u worried about doing it u can all ways box it up and ship it to me
ill do it for two hundred dollars
Old Jul 13, 2010 | 05:15 AM
  #15
91Warrior357's Avatar
rubber mallet and a piece of wood is all you need.
Old Aug 20, 2011 | 12:50 AM
  #16
Baileymac24's Avatar
My blaster is having the same problem right on the bottom right side of the motor. I am fifteen and have No money to pay someone to repair it and I was wondering if I can just get a new gasket only on the right side without taking the entire motor apart?? Also is there a way to break it open without a special tool?
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Ahtatu
Sep 28, 2015 12:14 PM
wrencher82
Sep 24, 2015 03:39 PM
nastyblaster100
Sep 13, 2015 01:19 PM
