Yamaha Warrior Shifting Problems
Old Jun 27, 2006 | 04:34 PM
Samdizzle's Avatar
Default Yamaha Warrior Shifting Problems
I own a 1987 Yamaha Warrior and I've recently comes across some issues with the shifting of gears, specifically shifting back into neutral. The shifting has become much more difficult from neutral through the rest of the gears as well and sometimes it will take a good 5 minutes to engage the atv back into neutral. It feels as if the peg will get stuck and not allow for any shifting. Usually, I will have to stomp on the peg and upshift and then down shift a few times and eventually it will fall back into neutral. Sometimes I will allow the clutch to slip for a bit and then it will allow for the gear to drop into neutral. I have this problem with first gear and neutral. I never have had this problem before so I was hoping to get some guidance on what to do. If anyone has experienced this, I would appreciate it if someone could share a possible adjustment or fix that was done.
Thank you!!
Old Jun 27, 2006 | 07:06 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
bent shift fork most likely .. my dad's quad is so bad it is like having a neutral lockout.. you have to shut off the quad to get it in neutral..
Old Jun 29, 2006 | 01:10 AM
twentycharacters's Avatar
im not trying to be an overly simple here but it may not be bent...
yamaha's lovely linkage...created notchy shifting espescially on a warrior. we used to have to spray ours with wd40 or some good silicon spray pretty often and it solved the problem for the most part...until the next fix of WD! i stomped pretty hard on my shifter before and never bent it- so unless you or anyone else went nuts on it and totally abused it, then it may not be bent just alittle stuck and needs lube. spray ALL the linkage pretty good. soak it down, then move the shifter as you spray. if that doesnt help, start replacing stuff...
let us know how it turns out.
toonces
Oct 16, 2019 12:11 PM
njrider64
Jul 4, 2017 01:40 AM
sara durrant
Jul 6, 2015 05:32 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
ranvette
Jul 4, 2015 06:13 PM
