it does not come out the light diff.lock. does not happen of 35kmh grizzly 660
#21
#22
could someone tell me how many milliters of 2-cycle to mix with a gallon of gas for a 40:1 mix? I bought some motul for my 98 yz 125 and I got spoiled using the mix chart on the back of yamalube. duh! I don't have any empties to re-use.
#23
#24
hello 2tv today did I go out of route and to the moment to go out in march that lights me the light of reverse gear blinking the whole moment because it is? I hope you know something thank you friend a greeting
#25
Ivanspain, the link you refered to for instructions on perfoming the diff-lock rev limiter override did indicate that the reverse light may blink when the override is in effect. So this is "normal". What this person did was put the diff-lock rev limiter override on a switch so he could switch it on and off, so his reverse light blinked only when he threw the switch.
Because of the problem you are having (where it thinks it's in diff-lock all the time) a switch wouldn't work for you, therefore the blinking light is something you will have to put up with (I think this is some sort of diagnostic code because it senses something wrong because of the rev limiter bypass). If the blinking light distracts you too much perhaps you can put a piece of black tape over it?...
#26
hello 2tv is entoces a normal truth on having removed the limiter of the diff lock that lights the red light of the reverse gear, (you know where there has the sensor the engine of the differences or some esquemá?) greetings
RticKwad
07-21-2015 03:00 PM
KimSJoh
14
07-18-2015 07:20 PM
