yoshimura rs3 slip onDisapointment
Old Jul 15, 2006 | 08:06 PM
  #21
Ozark38's Avatar
Default yoshimura rs3 slip onDisapointment
LOL!.........Dude, I thought you were kidding about the fan thing!..........[img]i/expressions/face-icon-small-happy.gif[/img]
Anyways, yes they generally are faster on the lean side but up to a point. I had my dialed in so good that it DID make a difference changing 1 size in either direction. 1 size richer, it didn't pull as hard.........and 1 size leaner, it pulled hard but wouldn't push to the MaxxRPM.
Old Jul 15, 2006 | 08:12 PM
  #22
Ozark38's Avatar
..........I just wanted to add it wasn't just the jets either. I moved the needles around, tried different pilots and mixture screw settings...........it was a little time consuming but the end result was rewarding.........[img]i/expressions/face-icon-small-cool.gif[/img]
Old Jul 15, 2006 | 10:24 PM
  #23
silent101's Avatar
shoot 1 size difference. So what do you reckomend i do, Get a dynojet kit or buy individual jets. The jets are 5 a peace and it takes two so every guess its 10 bucks down the tube. I was also serousoly considering the fan thing. I think it will help a bit. I will try it and then tell you guzs what it does. I dont know if i should put it on and start jetting or do the pipe then do it lator. What do you guzs think will it be worth my time or not?
Old Jul 16, 2006 | 09:23 AM
  #24
04RaptorLE's Avatar
I think you need to buy the filter, remove the snorkel,and drill a couple of 1 1/4 inch holes in your air box then jet it. I did this to mine using the full exhaust system and noticed a great increase in performance. I just went and bought individual jets from the dealer at $2 a peice.You will not notice any diff. if you do not rejet it. I know a couple of sizes does not seem like alot but you also have to move the needles and adjust the mixture screws. Then you will see a big diff.I know there are doubters but I have beat yfz's with similar mods and if you were beating piped raptors all ready then you should be beating them by more now. Good luck..
Old Jul 16, 2006 | 11:27 AM
  #25
silent101's Avatar
ya piped raptors with paddles and they were so amazed thinking i had major engine mods and i was only stock. That goes to shot you that if you dont know what you are doing you can really slow up you're quad. The guzs thought they were getting 15 HP from a big gun slip on, What a joke. He had a k&n and said he had the dealer install it all for him for like 500 bucks.
Old Jul 16, 2006 | 11:58 AM
  #26
Ozark38's Avatar
Dynojets are sized in increments of 5 above 150 (155, 160, 165, etc.) so yeah I could tell a difference in just changing 1 size. I like the Dynojet kit (mainly for the needles) but you can use either. They usually cost around $75 for a stage 2 kit and if you were to go with a full exhaust and open intake (Pro Flow K&N) you would need to order bigger DJs from them but they're only $2 apeice. In your case, I would just buy some Mikuni jets. I wish I could give you a good baseline to start from but I have no experience jetting for just a slip on and closed intake.
Old Jul 16, 2006 | 12:02 PM
  #27
silent101's Avatar
i guess ill just try 150/155 and see how she runs and then jet from there. Think that will be some were in the ball park?
Old Jul 16, 2006 | 12:38 PM
  #28
Ozark38's Avatar
That sounds like a good start. You might have to rejet again after you put on a K&N. Before you start, go to the hardware store and buy 8 hex (allen) head screws (size 4-70-10) to replace the bowl screws. When you go to remove the bowl screws you'll know why then and thank me later........... [img]i/expressions/face-icon-small-smile.gif[/img] .........and 3 more hex head screws (size 4-70-8) for the throttle cover.
Old Jul 16, 2006 | 12:41 PM
  #29
silent101's Avatar
ya i know what you're talking about i claned the carbs and the screws love to strip out. I had to dril the screw out and it was a pain.
Jeff Roper
Feb 1, 2022 11:48 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
