02 yamaha warrior clutch problems?
Old Aug 8, 2006 | 11:00 AM
infantrylife's Avatar
Default 02 yamaha warrior clutch problems?
I have a 02 yamaha warrior. I was riding yesterday and trying to do burnouts. I know stupid but im a beginner. Now it wont go forward or reverse. It just revs the engine. I am taking it to the dealer this weekend, but any info prior will be great.
Old Aug 8, 2006 | 04:28 PM
JLsparky7's Avatar
Have you tried all the gears? you might of just blown one up.
Is it stuck in neutral?
If it stopped working while u were doing burnouts then your probably right and it is the clutch.
Welcome to the forums as well [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 8, 2006 | 04:36 PM
yes i tried all the gears and no its not stuck in neutral, do you have any idea what it might cost if it is the clutch. im turning it into the shop this weekend, thanks for any help
Old Aug 8, 2006 | 06:55 PM
recon99's Avatar
Did it let loose all at once, or did it start slipping first? If it let loose all at once most likely you blew something up in the tranny, and that'll be expensive because the shop will have to split the case and most likely replace a bunch of the gears and shafts. If you got lucky and it's just the clutch a good shop will probably charge about $100 for parts and 2 hours of labor, so my best estimate would be about $250 if it's just the clutch.
Old Aug 9, 2006 | 08:40 AM
ok thanks a lot, i guess i'll see next week
Old Aug 9, 2006 | 09:54 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
maybe it just isn't engages in forward or revers??? lol that would suck
Old Aug 28, 2006 | 08:34 AM
It was the clutch, after two weeks and $260 later (clutch, oil, brakes) i was able to ride again yesterday. Thanks for the help
njrider64
Jul 4, 2017 01:40 AM
mikey426
Jun 17, 2015 03:53 PM
PuhiStrain
Sep 9, 2000 01:36 PM
zuki
Mar 17, 2000 06:04 PM
dunc_n
Aug 26, 1999 09:32 PM
