whats the difference in brake fluid
Old Aug 9, 2006 | 03:45 PM
warriorboy22's Avatar
Default whats the difference in brake fluid
i have a polaris predator and it says use dot 3 brake fluid but i have dot 4 can i still use dot 4 or does it have to be dot 3
Old Aug 9, 2006 | 04:12 PM
lancec2c30's Avatar
well I think the 3 and for satnd for the visocity of the fluid ( how thick it is) and the brake setup works bet on that specific thickness. So I am sure you could use it, but It woud probably be best to use what is recomended.
Old Aug 9, 2006 | 08:09 PM
recon99's Avatar
You can use anything that meets your rating or higher (in your case you can use DOT 3, 4, or 5). My warrior also says DOT 3 on the master cylinders, I bled it out with heavy duty DOT 4 and it gave it a much nicer, more direct feel, not so squishy and soft.
Old Aug 9, 2006 | 08:13 PM
AtvRacer299's Avatar
Recon99 is right. You can use anything that meets or is rated higher than what is says. If it says dot 3 , then you can use dot 3, 4, or 5.
Old Aug 10, 2006 | 02:39 AM
Doctorturbo's Avatar
GOT BOOST!
The higher the # the higher the heat rating.
Old Aug 10, 2006 | 11:08 AM
hondabuster's Avatar
Wrong.
Dont ever mix dot 5 with either dot3 or 4. They dont mix, because dot5 is silcone based, and dot3,4 are Polyalkylene Glycol Ether based.
Dot5.1 isnt silicone based, and could be mixed, but is much more expensive than 3 or 4, so there would be no point.
But dont use dot 5 in an older system made for dot3 or 4.
Heres a good on line article about brakes and fluids.
BRAKES
To answer the original question..yes interchange 3 with 4, the only difference is the boiling point, so you can use dot 4 in a dot 3 system, but dont use dot3 in a dot 4 system.
Shainasmash
May 8, 2017 06:38 PM
mattcraig1
Aug 19, 2015 03:48 PM
colt1126
Aug 18, 2015 10:38 PM
Stirling
Aug 9, 2015 01:49 PM
rcappie4
Jul 10, 2015 04:54 PM
