Big Problem!!
Old Aug 17, 2006 | 02:02 AM
396RaptorRyder's Avatar
Default Big Problem!!
Hey, I was riding my raptor yesterday and it quit. It started blowing fuses left and right. I could make it about a mile and a half on each fuse. It done this for 2 days. The last fuse it blew I changed it and wen about 1/4 mile and it quit. It wasnt the fuse. The lights worked and it would turn over. I even tryed bump starting it. Could this be because of a bad cdi box? Also it barely shifts. The clutch works fine. The shifter wont hardly move. You can pull it by hand and it is hard to move even with the clutch lever pulled in. Most of the time when you get it pulled up it wont click into gear. What could this be? Could this be the the shift shaft? Before it quit it didnt have a problem shifting, it was as smooth as when it was new. Does anyone have any idea what my problem is? Thanks for any advice.
Old Aug 17, 2006 | 02:38 AM
Z40005BR's Avatar
ok try tightening the battery bolts where the connections are...these things short out when theyre loose idk about the shifting...try burning out first maybe ur clutch is sticky...
Old Aug 17, 2006 | 03:04 AM
Ive checked the battery. I dont think the clutch is sticky because it was shifting as smooth as could be right before it quit. As soon as it quit, it wouldnt hardly shift back down.
Old Aug 17, 2006 | 07:03 AM
JLsparky7's Avatar
Checked your oil level?
Old Aug 17, 2006 | 08:18 AM
Checked if before I left. Its right on the full mark.
Old Aug 17, 2006 | 11:38 AM
ATVrider89's Avatar
Buy it now, explain it to the wife later!
If your blowing a lot of fuses maybee you have a short somewhere, either that or somthing similar happened to a freind of mine and he ended up replacing his magnito. As far as the transmission and its rough shifting I'd say you need to take that up to the dealer and let them have a look at it, my guess is maybee a stripped or broken gear?
Old Aug 17, 2006 | 12:03 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
i would say you have some major problems... but i would go as far as to say something on the stator has broken
Old Aug 17, 2006 | 12:15 PM
Yeah, Ill probably take it back to the dealer in a few days and find out what the problem is. Thanks for the advice.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
