05 Kodiak speed limited
Old Sep 19, 2006 | 10:36 PM
  #21
kennybres's Avatar
Default 05 Kodiak speed limited
Wish I would of read this a while ago. Same happened to me in deep muddy water. pulled 4 drain plugs let out an extreme amount of water. That got me going from 5 mph up to around 23 mph. mud caked in the clutch. grrr. easy fix and on my way! Happy trailes
Old Oct 8, 2006 | 04:32 PM
  #22
power123456789's Avatar
i have seen somebody with this problem i know exactly what is wrong your two breather pipes for the belt and tranny are in the front and back when on goes under the only problem is you can drain the water from the belt and not from the tranny because in the tranny you will have some mud an debris in the bottom of the tranny that is where the piece that shifts the geats should be.
when this happens it will ussually go only about 25mph when you have it wide open. It costs about 90$ to get it cleaned out. its nothing confusing or bad just dont ride it a whole lot until you can bring it somewhere to be cleaned
Old Oct 8, 2007 | 02:27 AM
  #23
Guest
Guest
Posts: n/a
http://cgi.ebay.com/ebaymotors...7733280&category=43976
Pehter
Oct 3, 2024 11:00 PM
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
YankeeRebel
Oct 6, 2015 06:44 AM
ReconBayou
Sep 23, 2015 02:41 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
