A-arms and Shocks
Old Sep 16, 2006 | 02:30 PM
AutoTimeS's Avatar
Default A-arms and Shocks
hello can same one tell me, i want to ride my banchee on race circuit and have some doble jumps i have the stock suspention what i have to do, because i all ready blend a lot of part several times, and yes i now how to jump, but some times my brother he use the bike....thanks
Old Sep 16, 2006 | 02:33 PM
recon99's Avatar
what parts did you bend? Because aftermarket suspension is expensive, and you don't want to have to replace more parts than you need.
Old Sep 16, 2006 | 02:50 PM
AutoTimeS's Avatar
the left upper a-arm and the shock, they are bent not to the side is bent from the down to up direction like a inch, i think sow i can fix them and i saw on ebay for 45+shipping but and now the fron t suspention wuin 2+1 for 200 plus shipping, bit i dont have any idea what are 2+1
Old Sep 16, 2006 | 03:58 PM
recon99's Avatar
If you are bending a-arms and shocks, it's probably best to replace both with aftermarket ones. It depends on how much you are willing to spend, but you can get a decent front suspension setup starting at around $800. Any less than that, then you have to start questioning the quality of the stuff you're buying, because you get what you pay for. If you're really on a budget, you can probably get away with keeping your stock a-arms, and just upgrading the shocks. That will cost you about $350 for some good ones.
+2+1 a-arms mean the a-arms are 2 inches wider per side, and move the front wheels 1 inch forward. That means the quad will be a total of 4 inches wider in the front, and the extra inch forward just makes it a little more stable.
Old Sep 17, 2006 | 05:42 PM
  #15
GrizzlyGreg's Avatar
The I-shock 5500 kit comes with every thing you need. New tie rods and breaded brake lines. Every thing is bolt up and fits like a glove. I'v only been able to ride in the dunes, and have'nt really gotten a chance to fine tune the front end. The thing I like the most about the I-shock kit is that it comes with every thing even brake line clamps and a bearing press tool. Also now I have 4 differant ways to adjust the front end. Right now I have the front end set up for cross country racing
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bigred20653
Sep 19, 2015 02:11 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
