blaster problems
Old Sep 20, 2006 | 09:17 PM
jimmyd03's Avatar
Default blaster problems
hey guys i have a 01 blaster for some reason after i run it for about 30 minutes or so the piston seems to keep locking up in the piston but after it sits for about 20 minutes its fine i pulled the cylinder and piston out and had everything checked out and everything is fine and i dont really want to do a top end again i only have about 3 months on it now(i dont ride it every day just on the weekends). Its bore .4 now and it has had porting done and jetting ,fmf gold series front pipe and fmf power core II silencer on it 1/2 reed spacer and boysen reeds stock carb and intake oil block off kit running 93 octane fuel with amsoil hp injector 2.6ozs of oil to a gallon does anybody have any thoughts or ideas on what could be causing this problem
Old Sep 20, 2006 | 09:20 PM
JLsparky7's Avatar
Are you sure its the piston?
You need to do a compression test.
Old Sep 20, 2006 | 09:25 PM
jimmyd03's Avatar
what should the compression be around any ideas i think the last time i did it,it was about 93 lbs
Old Sep 21, 2006 | 11:16 AM
Lilhobbit36's Avatar
i know this may seem out there but u sure that ur air fuel mixture is right cause if your riding for 30 minutes and it quits it may be drowning its self. otherwise your top end may be F. Also it could have bad rings. i would check carb.
Old Sep 21, 2006 | 10:48 PM
Boomer2's Avatar
The compression of a stock blaster is 140 to 160 psi. Does it die or does it actually lock up where you can't even kick it over.
Old Sep 22, 2006 | 08:02 AM
JLsparky7's Avatar
Those numbers i believe are very wrong. A milled head banshee gets 150psi of compression. I believe a blaster should be around 115psi. If you have another gauge available use it to recheck your numbers. Checked your reeds lately?
Old Sep 22, 2006 | 08:42 PM
Boomer2's Avatar
Thats what the clymer manual said.
Old Sep 23, 2006 | 01:05 PM
jimmyd03's Avatar
it locks up solid but after about 20 minutes or so it kicks right over again and starts up
Old Sep 23, 2006 | 01:07 PM
jimmyd03's Avatar
reeds are new and it dosent die ither it runs strong and very powerful no miss just locks
Old Sep 23, 2006 | 06:06 PM
Boomer2's Avatar
Do you have the correct piston and rings for the overbore.
