660 rapter Misfiring
Old Sep 29, 2006 | 10:11 PM
Dutchie's Avatar
Default 660 rapter Misfiring
I have a 02 660 Raptor,it ran good before I put new cluch pack and rear bearings in it.
Right now it ides no probem but when you put the gas to it, It misfires any help would be nice. TIA
Gas is good
new plug
new coil wire
Old Sep 29, 2006 | 10:22 PM
paintballbanshee's Avatar
jetting is off i doubt you wil be able to jet it id get someone around you that knows stuff about dual carb jettings.
Old Sep 29, 2006 | 10:47 PM
ds650ctracing's Avatar
More than likely you are not "misfiring" you are probably rich or lean on the carbs ? Have you messed with the jetting ? Has the quad been setting up for a while , you may need to give the carb's a good cleaning.
Old Sep 30, 2006 | 11:22 AM
Dutchie's Avatar
never touch the carbs I parked it for 2-3 months got it out to fix the cluch and now it won't revup? TIA
Old Sep 30, 2006 | 06:31 PM
aqharoper's Avatar
Clean the carbs out. Mine will do the same thing if I let it sit. I always empty the tank and run the carbs dry if it sits for more than a week or two.
Old Sep 30, 2006 | 07:52 PM
rruser's Avatar
Parking brake?
Old Sep 30, 2006 | 09:18 PM
Raptor149's Avatar
check the easy fixes first. make sure your parking brake rev limiter is fully disengaged and not kicking in. also, make sure you're getting good spark to the plug. check and clean the air filter. examine all your intake boots, make sure none are loose or cracked. go over your wiring harness and make sure all your plugs are connected. if none of this clears it up, then it may be time to look at your carbs. if you haven't adjusted the jetting, that is probably not your problem.
Falcon150
May 25, 2015 05:36 AM
deathmetal
Apr 10, 2014 10:02 PM
Punisher
Jun 4, 2002 08:29 PM
SandmanBlue
Jan 10, 2000 11:13 AM
