Wolverine/Warrior Carb question
I forgot to mention...I picked up 4' of fuel line to use just incase my parts don't come in. Why that long? So I can route to to a cleaner, dryer location...maybe the battery box.
Running the bowl vent/overflow into the battery box? Bad idea. First, it's gravity fed, so if the line doesn't run to a point lower than the carb, that excess fuel that sloshes out won't have anywhere to go, and it'll start running like crap and maybe even shut off completely. Also, I don't think I'd want raw fuel dumping into the battery box even if the fuel would flow uphill through that line. Fuel + small enclosed space + potential for sparks = potential to blow your seat off and end up running through the woods with your pants on fire [img]i/expressions/face-icon-small-tongue.gif[/img]
The overflow/bowl vent line on my carb just runs down the back of the engine and dumps in front of the swingarm, and doesn't have any kind of check valve on it, just open hose. I've ran my warrior through some pretty deep mud and water (see pics for proof) and nothing made it up that fuel line, the bowl on the carb was spotless the last time I had it apart.
Mud1
Mud2
Mud3
Mud1
Mud2
Mud3
#15
Thanks! That post was really really helpful. I guess not having any hose on the bowl is what caused the stuff to get sucked in. Like I said, I don't do any big mud bogging, but semi deep crossings do take place.
So your tube just runs down the frame and near where the swingarm mounts? So I'm assuming that tube is about 18" long?
#16
18 inches would be a good estimate. It just runs from the carb, straight down the back of the engine, and a couple inches past the swingarm pivot (which the hose is loosely zip tied to, to keep in place)
#18
Got the parts installed and went riding Monday. It was really wet and I did some water crossings. No problems with the carb so far! I haven't taken the bowl off, but I assume all is well. The machine ran great all day.
