Reverse? on my 660
Old Oct 29, 2006 | 08:52 AM
finny6944's Avatar
Default Reverse? on my 660
I feel like a jerk comming on here with all of these questions , but the dealer hasnt been the most friendly with me. I am not sure how to get the quad into reverse. I thought it was too 1.put quad in nuetral 2. turn **** to right 3. pull the clutch in 4. put quad in first.. But everytime I do that i end up in 1st.. If anyone can help me out I would really appreciate it.
Dan
Old Oct 29, 2006 | 09:45 AM
Raptorracer2051's Avatar
Put the quad in first gear, hold the clutch, then turn the **** and kick down into reverse.
Old Oct 29, 2006 | 09:47 AM
getblown's Avatar
Hey, its a bit tricky the first time, I find it easier when you are in first, pull the clutch in, turn and hold the rev switch and then press down on your shifter. Reverse is below 1st, R-1-N-2-3-4-5. But unfortunatly reverse is pretty much useless on the raptors due to the rev limiter, but once you bypass that it is great. Do a quick search and you will find the procedure to do so. Good luck
Terry
Old Oct 29, 2006 | 10:14 AM
Bigdaddy660R's Avatar
I'm Short and Very Ugly.....
Finny....
it's just like how the other poster have described.....
I would add get used to your machine b-4 eliminating the reverse rev limiter. I have seen and experienced some unfavorable episodes with it eliminated.....BE CAREFUL and have fun with your new raptor.....
SJ's Avatar
SJ
Don't feel like a jerk. That is what this Forum is all about. Giving us a place to communicate with each other. If someone has a problem with your questions they shouldn't reply. Good luck and have fun with your new toy. Be safe.
Old Oct 29, 2006 | 12:16 PM
finny6944's Avatar
ok guys thanks alot. I figured it out this morning. Once it's in reverse it's kind of tricky to get the bike rolling without stalling it. I did figure it out..Thanks alot.
Dan
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
poutlaw525
Sep 9, 2015 03:19 AM
