Air filter..
Old Oct 29, 2006 | 07:14 PM
finny6944's Avatar
Default Air filter..
I was wondering if it was best to replace the air filter or to just clean it. If I should clean what is the best way. Thanks again for all the help. You have really made it easy for me to enter the atv world.
Dan
Old Oct 29, 2006 | 07:17 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
use paint thinner
Old Oct 29, 2006 | 08:04 PM
BassBlaster's Avatar
Your airfilter comes apart. Take it apart and clean it all with warm soapy water. I use dish soap. After it dries spray the foam real good with air filter oil. I use Uni air filter oil, like $4 a can, lasts a long time.Put it all back together. Wear rubber gloves if you have them, the oil is a thick sticky mess.
Old Oct 29, 2006 | 08:24 PM
finny6944's Avatar
OK thanks pal...How often do you clean the filter?
Dan
Old Oct 29, 2006 | 08:59 PM
hondabuster's Avatar
The short answer is when it gets dirty and usually that is determined visually. Some do it after every ride, especially in dusty conditions. I would say 10 hours of run time is long enough.
Heres a good how to from twin air
here
But the instructions work for all foam type filters.
Old Oct 29, 2006 | 09:07 PM
finny6944's Avatar
OK thanks..
Dan
Old Oct 30, 2006 | 04:07 AM
GJRonK's Avatar
With any foam it's best not to use any chemicals that are not specified for cleaning foam filters as the odd chemicals can break down the structure of the material and ruin its dirt collecting capability--even if you can't see the difference.
The exception is dish soap (I use Dawn) which is safe on the material and cuts the oil loose from the medium. You may have to wash it several times to be effective.
You don't need to over-oil with the tacky filter oil, that's why using gloves lets you work the oil in without having too much on. Be sure to oil the inner foam on a double foam model.
GJRonK
Old Oct 30, 2006 | 08:49 AM
Speedy2222's Avatar
"working it in" works the oil out of the foam... the idea is to get it dripping blue(literally) with filter oil
Whiskey Mike
Dec 23, 2013 02:58 PM
fulk112
Oct 11, 2012 06:50 AM
Brewhouse
Jun 11, 2011 07:48 PM
bigR
Apr 22, 2003 03:33 PM
300expressor
May 10, 2000 06:08 PM
