Raptor 660 wont start
Old Nov 21, 2006 | 09:21 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
Default Raptor 660 wont start
ground it to the head... best palce to ground when checking spark
Old Nov 21, 2006 | 10:22 PM
Temper50's Avatar
Before tearing anything more apart, pour a little bit of gas or carb cleaner into the spark plug hole, then try to start it, if it starts then dies out, then you know you're either not getting fuel (be sure fuel is actually getting to the carb BEFORE blaming the carb) or you have a massive air leak-check the carb boots to be sure none of them popped off.
If it still won't start or fire even after doing the above, then look into the ignition system for a problem. I've heard of 660 motors having STATOR failures, I believe one of the symptoms is that you don't get spark while pushing the starter button, but do get spark after you release the starter button...wierd, huh?
EDIT, I forgot to mention these links to RickyStator.com if you find the stator is bad or suspect it is:
Pickup coil only to repair the original stator's faulty pick up coil
http://www.rickystator.com/catalog/p...roducts_id=146
Complete new stator assembly with pick up coil:
http://www.rickystator.com/catalog/p...roducts_id=140
You could email them for more info on their stators or on how to find out if yours is bad:
info@rickystator.com
Old Nov 21, 2006 | 11:17 PM
flyinscrammy's Avatar
Yes the intake comming off could have caused the problem, (air fuel mixture to the Intake manifold), use the starter fluid and find out if you get it to kick or attempt to start. also, on top of your motor is the head, there are two screws that hold a plate down on the head, take those off and use either the back of a screwdriver or something not too hard to push on the intake and exaust valves, there are three there. If one of them has tons of freeplay you have broken one of the valve, intakes or something within the head. You could have possibly gotten a big gulp of sand in the motor....... In that case, it's rebuild time, it'll cost about $600.
Old Nov 21, 2006 | 11:19 PM
thesuffering's Avatar
so i tried your suggestion, only put a small amount of gas in the spark plug hole, and it did nothing. so you think its an electrical problem then. it wont push start either
Old Nov 22, 2006 | 02:36 AM
  #15
Fulltiltrider's Avatar
I would suggest finding someone around you that has a raptor and first pull off their coil wire put it on your bike give it a shot, if that doesnt work try their cdi ( Cant take back electrical components so this takes out the guess work)
Good Luck
Old Nov 22, 2006 | 02:49 AM
  #16
velocyraptor's Avatar
can it be a bad coil?
Old Nov 22, 2006 | 11:49 AM
  #17
I had this problem on my 250 exept I started with the cdi and it ended up being the coil i still had spark but it wasnt consistant
Old Nov 22, 2006 | 01:33 PM
  #18
the more i talk to you guys, the more i feel its probably the electrical system, since i cant get spark consistantly. is there any way with a multimeter to test where the problem is?
Old Nov 22, 2006 | 07:09 PM
  #19
trialsrider172's Avatar
I think you do have spark. its not suppose to be a constant flow of sparks, just one every 20th of a second or so. If your getting a few sparks, you do infact have spark. i would clean the carb completely first off. Also, make sure gas is flowing from your tank, through the line, to the carb. make sure your breather hose is flowing from your gas cap also, this can cause gas not to flow from the tank.
check those things and see what you get
Old Nov 22, 2006 | 07:21 PM
  #20
i dont even get spark that much....
