2003 Kodiak 400 4x4 stuttering
When I press the gas 1/4 of the way it begins to stutter. I took the fuel tank off and drained it and replaced with new clean gas. I still have the same problem. It has about 500 hard miles on it and this is the first problem I have had with it. Can anyone tell me what I should look for to fix this? Thanks
I got it fixed and ready to go. What I did was took out the carberetor went to the jets taken them out then sprayed with carberetor jet cleaner. I then sprayed the remainder of the carb. and put it back together. It now runs smooth and nomore stuttering or backfiring.
Get some seafoam to add to your gas tank , it's a fuel cleaner/stabilizer and will help keep your quad running good ; you can get the seafoam at O'Reallys, Auto Zone and Advance Auto Parts Stores ! I got mine from O'Reallys for $4.99 + tax , it may be more in your area ; depend's on your location i live in north west Ga. ! The seafoam is great stuff it will clean the entire fuel system , and also clean's the combustion chamber as well ! .....................williebee
Impalaman
1) Engine problems..
12
11-08-2015 07:17 AM
greg86hd
09-16-2015 12:32 AM
