Warrior 350 Performance Issues
Old Dec 7, 2006 | 05:23 PM
  #31
SnakeDoctor's Avatar
Default Warrior 350 Performance Issues
Deanz400:
Thanks for the thread. What did you do to correct the problem? Did you simply disconnect the switch and bridge the connector?
Good information!
Old Dec 7, 2006 | 07:31 PM
  #32
cheitman's Avatar
My parking brake has been removed. Still have problems. Will check the reverse though.
Old Dec 7, 2006 | 07:45 PM
  #33
Thanks for the reply, Chietman. Hopefully I can yard off the brake switch and peek at the reverse switch this weekend. I will advise.
SnakeDoctor out
Old Dec 7, 2006 | 07:50 PM
  #34
cheitman's Avatar
there is a reverse sensor in the engine. the wire attaches by the foot shifter. I wonder if you disconnect the wire if it would disable the rev limiter? If it wasn't so fuc$ing cold here I would try it. It's in the single digits and there is no way! It's supposed to be 50 this weekend, maybe I"ll try.
Old Dec 7, 2006 | 08:04 PM
  #35
Cheitman:
Very good lead on this problem. Asfasasu3, in addition to others, believes this is the potential problem. I will trace the wiring schematic before starting and research how the all interconnect. If I discover anything, I will definitely share with you and Deanz400 anything I discover.
Thanks again, Mate!
SnakeDoctor out
Old Dec 11, 2006 | 05:54 PM
  #36
deanz400's Avatar
my main problem was the parking switch ,the reverse was mainly some corrosion and a little bit loose .
Old Dec 12, 2006 | 04:14 PM
  #37
deanz400's Avatar
Well whats the verdict on your machine .?
Old Dec 13, 2006 | 08:24 PM
  #38
Deanz400:
Thanks for the inquiry. Actually, the weather has been a bit stormy around here and I have not ventured into the barn to yard it out. The weather idiots claim that the weather will be improving over the weekend; if so, I will pull it out Saturday. I will definitely let you know if there is any improvement.
Thanks again, Mate!
SnakeDoctor out
Reactant
Mar 30, 2022 02:08 AM
Nondem
Feb 22, 2020 12:20 PM
manuelrivera
Aug 8, 2015 04:34 PM
Ashley S
Jul 31, 2015 09:46 AM
Reactant
Jul 16, 2015 10:29 PM
