Lot's of questions...
Old Dec 5, 2006 | 04:11 PM
invador's Avatar
Default Lot's of questions...
Well since no one posted any replys in the sport section I thought about posting it here.
Hey I have a Raptor 350 06' I'm looking to put some more power and money into it. I first want to ask what is the stock raptor 350 front sprocket size? Second I want less acceleration but more top speed so should i get less teeth or more, and how much more top end speed does it add. Once I buy my sprocket how will I know what size of a chain I need? I then want to know what exhaust I should get to make up for some of the acceleration lost. I was thinking of a WB e2 or a LRD Pro4. Once I pick my pipe what type of jetting and filter should I get? I know a lot of questions but try and answer what ever you know.
Thanks.
Old Dec 5, 2006 | 04:45 PM
RUFFCOUNTRY's Avatar
Your stock front sprocket is 13 tooth rear 38. Go up a tooth on the front for more top end you will sacrifice a little acceleration, you shuoldnt need a new chain I think theres enough room for adjustment. Any of the exhausts you mentioned would be a good chioce, as far as jetting get the manufactuer to recomend something dont forget to mention your alltitude. The air filter I went with a K&N but im thinking foam filters may offer more protection
Old Dec 5, 2006 | 06:29 PM
invador's Avatar
Thanks, I think I might go with the LRD it gives more low end which this quad is lacking. Any more help would be appreciated.
toonces
Oct 16, 2019 12:11 PM
bmark0610
Sep 7, 2015 09:42 PM
1ArmBandit
Feb 10, 2013 01:17 PM
illin
Mar 27, 2007 10:55 PM
Troyer23J
Jun 15, 2004 08:16 AM
