reverse to forward on warrior
Old Dec 5, 2006 | 05:06 PM
dchicora's Avatar
Default reverse to forward on warrior
Recently purchased a used warrior. It's a 99. When I put it into reverse and then back up a bit and then try to put it back in forward, it is very hard to get back in forward. Any input on this?
Old Dec 5, 2006 | 05:09 PM
lucasislight's Avatar
i hear alot of warriors have this problem. i just release the clutch a little when i pull the lever to the forward position and it clicks right in!
Old Dec 5, 2006 | 07:47 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
it takes practice but if u pull the clutch( still rolling) and move it in one swift motion.. you won't get any clicks and you'll be able to get it easily...
if u are already stopped.. just slip the clutch a little..
Old Dec 7, 2006 | 10:24 PM
dchicora's Avatar
Ok, thamks all. Yea, I have noticed before, that is the only way I can get it back in forward. I didn't know if this was a mechanical problem or what. Sounds like it is a warrior normality. Or should I say abnormality?
Old Dec 9, 2006 | 01:10 AM
trialsrider172's Avatar
mine does the same thing. usually if u push it as far forward as u can then let the clutch out, pull it back in quikly, put it in gear and give it alittle gas u can get it right in with it revving alittle above idle.
Old Dec 9, 2006 | 02:11 PM
Speedy2222's Avatar
also, if u are truly struggling.. shift it into neutral and then move it..
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
2many2ride
Sep 27, 2015 04:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
