Raptor 700r HELP!!
Hello my friends i live in argentina and i have a raptor 700r... yesterday i change the oil and the oil filter.. in the manual say that the raptor take 1.85lts of oil when you change the oil filter... i put first 1 liter of oil... and later a put 1 liter more of oil... i turn on and run for 500meters to the oil move and circulate.. when i cheking the oil with the dipstick the oil set to low.. (very low).. how i can to make a good oil reading on my raptor 700? i dont now... please help me.
Originally posted by: nicolas1989
thank you, but i need to now how i chek the oil? how much oil you put in liters? thank you.
You fire it up let it run for a couple min giving it some throttle then pull the dipstick out of the top of the oil tank and see what the level is.
Yor profile says your from Mississippi do you know how to convert qts to liters? I believe 2 US qts are 1.89 liters so I guess after doing the math the manual is pretty darn close.
randy i am from argentina, i chose missisipi beacause i dont cant to chose argentina... when you change the oil you change the filter to?
i put like 2.1 liter but when i chek the oil.. the dipstick is in low level... and to chek, first i turn on the engine (engine cool) and let it in idle speed like 5min and turn off and check the oil..
i dont now what hapen? maybe they need more oil? in the manual say 1.85liter... but the total amount is 2.3liter in the manual...
i wait for your help.
The 700R has a dry sump oil system with an external oil tank. You can do it either way as long as you put the 2 gts or 1.89 litre in. The manual does not say to but I also pull the oil fill plug and right side case by the clutch actuator and put 1 qt in the crank case and I put the other qt in the oil tank just because I don't like to put a qt and a half in the oil tank fire it up and then shut it down and pour the other half qt in.
nicolas1989, I don't know what to tell you, I have not had this problem, when I put 1.89 liters which is 2.0 US quarts in my oil level is right at the full mark on the dipstick after I have run it and let it sit for a while and check it.
Be careful not to over fill, as long as you are on the dipstick between full and add you are in the safe operating range. Let it sit overnight and re check it and see what it says. sorry, that's all I got [img]i/expressions/face-icon-small-confused.gif[/img]
thank you very much... i check the oil tomorrow... how you change the oil? i take out the crankcase screw and the oil reservoir crew and let it dry and take out the oil filter out... you do the same?
in 20 days i go to california of vacation and i want to buy some mods to my raptor... i was thinking to buy a air filter yamaha gytr and a exhaust system with the pipe all yamaha gytr... if you enter to yamaha-motor.com you cant to see... if you now some better than that tell me? or another mod that is very important for the raptor...
thank you
compadre
thank you
compadre
According to the yamaha service manual the 700r holds 2.3L if you overhaul it. If you change the oil and filter it should take 1.85 L of oil, 1.30L goes in the oil tank and.55L goes in the crankcase. These are specs from the yamaha service manual. When checking the oil level, run for 2 minutes then shut off for two minutes until oil settles before checking. Do not screw in the dipstick in when checking oil level.
Alex Rodak
09-12-2015 09:39 AM
