starting
Old 01-21-2007, 08:25 PM
xjjeeperman's Avatar
Default starting
i doesn't do it often but sometimes when i push the start button all i hear is a click. i felt around and you can feel movement from the starter relay when this happens. any ideas of what could cause this or am i gonna have to replace the relay. thanks *****
Old 01-21-2007, 09:08 PM
JLsparky7's Avatar
Default starting
Are all your connections tight with a good battery?
Old 01-22-2007, 01:01 AM
hondabuster's Avatar
Default starting
The relay is the last thing i would suspect...its just an electromagnet, with some contacts, and they rarely go bad.
Like was said, hows the connections at the battery? clean and tight? If they look good, remove the battery and take it to an auto parts store like napa, and they will do a free load test. Most likely the battery is failing under load, and a load test will determine if the battery is good or bad.
MikeyBoyesq
11-27-2020 02:44 PM
Mkp
03-28-2020 03:50 AM
tiresharkdbb
09-03-2017 02:06 AM
garyt1975
06-05-2015 08:53 AM
1000gade
05-27-2015 12:37 PM
Quick Reply: starting
