raptor 350 74.3 mph, no way!
Old Jan 24, 2007 | 08:28 PM
  #31
2FAST4URASS's Avatar
Default raptor 350 74.3 mph, no way!
I have a trail tech endurance spedo and with my few mods and 12/40 gearing i can only hit 54-57 running hard with stock gearing id top out around 60-63 on the road but id like the low gearing much better and its not your magnet it's just not dialed in rite.
QUAD
WHEEL SIZE
TIRE
MEASUREMENT
400EX
22 inches
Stock dirt
1676 mm
Raptor
23 inches
Pure Sport Bandit
1727 mm
Raptor
21 inches
Stock dirt
1572 mm
Raptor
21 inches
RA Shredder dirt
1562 mm
Polaris Magnum 2WD
Stock dirt
1803 mm
Honda Four Trax 300 23 inches Stock dirt 1715 mm
Kawasaki Bayou 4x4 23 inches Stock dirt 1746 mm
Polaris Predator 21 inches Stock dirt 1572 mm
Old Jan 24, 2007 | 09:41 PM
  #32
kyledvor61's Avatar
I'm not sure whats up with the computer if it's not dialed in right or what. I bought the kit and installed it and ran the hell out of it. so what do i do now?
Old Jan 25, 2007 | 12:21 AM
  #33
IT HAS TO BE SET... read all of this.
What wheel size should I put into the computer?
The first thing you need to know for any of the computers is the rolling circumference of your wheel. For the ATV's, a good mid-range number to use is ---1676mm--- (number derived from a 400EX with stock front tires and minimal treadwear). Here are some additional numbers for consideration:
QUAD
WHEEL SIZE
TIRE
MEASUREMENT
400EX
22 inches
Stock dirt
1676 mm
Raptor
23 inches
Pure Sport Bandit
1727 mm
Raptor
21 inches
Stock dirt
1572 mm
Raptor
21 inches
RA Shredder dirt
1562 mm
Polaris Magnum 2WD
Stock dirt
1803 mm
Since there will be some variation due to different tire styles and treadwear, you may make the measurement yourself by marking the front tire and the ground with a felt pen, then rolling the bike/quad until the mark makes one full revolution and returns to the ground. Then make another mark on the ground next to the mark you already put on the tire. Measure the distance on the floor between these two marks and this will be the rolling circumference of your tire. To convert this number to mm multiply by 25.4.
If you want your computer to be exact, set your computer wheel circumference to 1676mm (or whatever you determine from the above method). Find a length of road where you know the exact distance. Ride the distance and note the distance you computer reads. Lets say your road was five miles and your computer showed it as 4.95 miles:
1676/X = 4.95/5.00
Solving for X gives you:
X=1676*5.00/4.95 = 1693mm
What is the difference between the Panoram model and the Endurance model?
Our latest computer is Endurance. We no longer sell Panoram. Improvements/changes are:
Scratch and chemical resistant screen for the Endurance computer.
Different internal electrical contacts for the Endurance computer.
Faster processor for the Endurance computer (updates speed at 2X the rate)
Different programming for the Endurance computer to allow for Enduro riding (increment and decrement)
Impact resistant case for the Endurance computer.
Old Jan 25, 2007 | 02:04 PM
  #34
aaaaaaa's Avatar
can't answer that but i have a question but it may seem stupid to you guys. if you all know anything on dirt bikes you know you can put a big bore kit on them. is it possible to do that on a quad. (don't laugh at me if it that question sounds stupid)
Old Jan 25, 2007 | 04:29 PM
  #35
RaptorRidn9000's Avatar
YEA u can make a raptor 660 a raptor 780
http://www.trinityracing.com/product...60perfkit.html
Old Jan 26, 2007 | 12:02 AM
  #36
YOU CAN MAKE A WARRIOR / RAP 350 A 440 MICKEY DUNLAP...IT'S A MONSTER ive ridden a warrior with it ' its as fast as a stock z400 but has tons of low end and mid range power makes it a awesome trail quad!!!!
Old Jan 26, 2007 | 12:57 AM
  #37
4wheelerfred's Avatar
kid accross the road has a rap 350 thats stock and he is about 5 mph faster then me toped out on the road, and im on my piped kingquad my motor is a 305 lol but im going about 54 wide open lol
Old Jan 26, 2007 | 01:19 AM
  #38
ThaChad's Avatar
Originally posted by: 07Wolvey450
I totally agree... you only have a couple performance mods, none of which will increase your top speed that much. Maybe your speedo. is off? I don't know. How old are you? I'm 14 and finally got 6000 to spend on a Wolfy 450, not bad if you ask me.
A 14 year old with $6000? Wow, I wish I had your parents when I was your age!
Must be nice.
Old Feb 17, 2007 | 10:42 PM
  #39
kyledvor61's Avatar
I know this thread has been dead for awhile but i had some questions. First I was looking at one of the web camshafts on their website. I believe stock lift is only .382, they had one on their website that was a .390. I think this is too small to probably even feel a difference. they also had one that had a .430 lift for the same money. But it says major top and middle end gains for racing engines. First I dont want to kill my bottom end, and It says for race engines. I have for perfomance is a pipe,filter,sort of lid, and a smaller sprocket. I'm pretty sure thats not a racing engine. I dont know if it would work or not. If it wont will a bigger compression piston help? thanks for youre help
Old Feb 21, 2007 | 12:55 AM
  #40
Jake795's Avatar
Bigger compression piston will definately help, just make sure to run higer octane gas. With the bigger camshaft you will probably have to change out the valve springs in order to get the valves working correctly. The smaller lift one that you saw is probably designed to work with a semi-stock motor without changing the springs. BTW the higher compression will give you killer low end power!
Jake
