No Spark
Old Feb 10, 2007 | 04:39 AM
yarnots's Avatar
Default No Spark
I have a 03 Kodiak 450. The coil wires rubbed on the frame and shorted out. It melted most of my wiring harness. I have since replaced the stator, wiring harness, coil and the CDI box. I still have no spark. Everything is hooked up. I am out of ideas and am finally ready to call it quits and take it to the Yamaha shop. Any ideas on anythng else I might try? Thank you in advance.
Old Feb 10, 2007 | 01:39 PM
popup's Avatar
Default No Spark
try the pulser coil/pickup coil the small black thing with the stator.mine was done do a ohm test should be 500 ohm+or-50 ohm set the ohm tester to 2000 to test.good luck
Old Feb 10, 2007 | 09:29 PM
yarnots's Avatar
Default No Spark
Thank you
Old Feb 10, 2007 | 10:17 PM
PedroF's Avatar
Default No Spark
Try testing your main switch and all other switches to make sure they are OK cause they could be telling the cdi box not to allow spark. oh everything out to make sure it all works use the manual it should have all the specks in there for you...
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
