if its not the relay then what is wrong???
Old Feb 14, 2007 | 07:09 PM
Raptor450's Avatar
Default if its not the relay then what is wrong???
Originally posted by: lucasislight
yes, its in neutral the light works, what else could it be? i dont have a multimeter, i use my buddies when i need it, but i think im going to invest in one today. that gives me an excuse to go for a drive in the Nor'easter! thanks for the help guys i truly appreciate it i know i can figure this out without bringing it to the stealer.
You really dont need a multimeter, but it wont hurt to have one. The only other thing I can think of that it could be is the wiring or a plug between the starter button and the relay. The 2 small terminals on the relay need 12VDC to activate it. That takes a positive and a negative to give you 12VDC. When you hit the starter button that sends 12VDC + to the relay. 12VDC - should already be there possibly all the time. If you lose either the + or - that will keep the relay from engaging. Another test you can try with a meter is to ohm out the small terminals on the relay. These terminals should read as a "short" or connected, or if you have a meter that beeps when you have a low resistance, the meter should beep.
bmxatv10
Oct 14, 2022 06:23 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
cboler9
Sep 24, 2015 08:35 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
