clutch warrior
Old Feb 19, 2007 | 09:50 AM
noholdinback's Avatar
Default clutch warrior
I have 2000 warrior the clutch is real hard to pull in the lever. Is there any kind of adjustment that may fix this or do I just need to get a new clutch kit.
Old Feb 19, 2007 | 10:00 AM
4wheel4food's Avatar
Welcome to the world of sore left hands and Warriors....I have
two of them '00 and '03...This is one of my few gripes about the
old crusty veterans...The clutches are alot tighter than most newer
bikes...My Z400 is like a feather compared to my Warriors...I have read
many posts on many diff. sites and it just seems to be the nature
of the beast...I would loosen it up as much as you can (free-play) and
just get used to it...Don't think there is probably anything wrong with
your clutch, just a bad design by Yamaha....Good Luck....
Old Feb 19, 2007 | 10:52 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
change your clutch cable
Old Feb 19, 2007 | 11:30 AM
what with yamaha oem or aftermarket.
Old Feb 19, 2007 | 11:55 AM
Speedy2222's Avatar
RMATV has one for i bleieve $13 that has teflon in it but i replaced with OEM... i'd say OEM.. unless u live 50+miles from a dealership.. then i'd say buy stuff from RMATV.. but otherwise it's only like $15 fro mthe dealer.. or try to get a motion pro from a dealer..
Old Feb 19, 2007 | 11:59 AM
Did this loosen up your clutch? If so, I will do on both of mine....
I just have never read anywhere that it helps....I know the Warrior
clutch weras out my daughters hand...Thanks
Old Feb 19, 2007 | 12:02 PM
Speedy2222's Avatar
loosening won't affect anything.. especially if the clutch cable is frozen.. you'll eventually break the cable
Old Feb 19, 2007 | 12:09 PM
By loosen, I meant did it make it easier to pull/engage....Because my Warrior's
clutches are helluva lot harder to pull compared to my Z400...
Old Feb 19, 2007 | 12:10 PM
Speedy2222's Avatar
depends when the last tiem your cable was changed... i know mine was hella hard up to the ponit where it broke..
Old Feb 19, 2007 | 09:34 PM
Raptor450's Avatar
Just for a 2nd opinion, change your clutch cable! You cant lube them enough to free them up when they get stiff, and when I changed mine it was like a night & day difference.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
jbrewster94
Sep 23, 2015 04:16 PM
