clutch cable
Old Feb 24, 2007 | 11:33 AM
Raptor660JC's Avatar
Default clutch cable
I just replaced my clutch lever, got rid of the bulky stock one with the ebrack and all that crap on it...however it seems like the cable is too long now, as soon as i release the clutch a HAIR literally it engages. it barely goes into gear while i have it squeezed tight...i have the thumb screw out as far as it can go without coming out,,is there anywhere else I can tighten the cable?
Old Feb 24, 2007 | 11:56 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
where the cable goes into the perch adjust that screw in and reset the lock nut
Old Feb 24, 2007 | 06:32 PM
recon99's Avatar
Yeah, at the bottom mounting point of the cable. You can also pull the arm off the clutch shaft and move it over a couple notches on the splines to take up some of the slack.
Old Feb 24, 2007 | 10:52 PM
I adjusted the screw on the perch and its liiterally out on the last thread, i'll have to try to adjust it at the clutch shaft like recon99 said..
Old Feb 25, 2007 | 12:27 AM
Speedy2222's Avatar
adjust it IN not out..
Old Feb 25, 2007 | 08:59 PM
If I thread it in (to the left) the line loosens up and it's useless.
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
craacker
Sep 9, 2015 04:32 AM
cdstang
Aug 31, 2015 07:52 AM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
