help need 06 blaster knocking
Old Feb 26, 2007 | 06:56 PM
Dunedog805's Avatar
Default help need 06 blaster knocking
i looked on vitos site the kits 45.00 bucks for evry thing u need its worth it trust me!
Old Feb 26, 2007 | 08:56 PM
beaverblaster22's Avatar
cool thanks for the help with the tors i will deffently look into that i can care less about the idle for now the knock is my big problem i just brought up the idle because i thought it had something to do wth the knocking but thanks for the info will deffently think about that
Old Feb 28, 2007 | 04:53 PM
well today i change the plug and tranny oil quad is still koncking to doesnt sound bad when u first start it butt as soon as u take it down the block and it warms all the way it gets loud i still have the oil injection on it would that screw it up if i changed the main jet i went from a 290 to 310 could it be i throw the mixture off thanks
Old Mar 1, 2007 | 09:03 AM
well nevermind on the mixture i was told that it wouldnt effect anything so i think i am just going to take it to a shop today to see if they can tell were the noise is coming from and y thanks for the help
Old Mar 1, 2007 | 10:26 AM
  #15
1988fast250x's Avatar
Dump that oil injector! that think is a waist of time and can potentially cause alott of trouble.. what kind of oil are u running?? dont use the cheep stuff it just robbs your bike of power and everything else! I run Maxxis race oil.. in all of my 2 strokes.... its like 8 or 10 bucks.. works great... but that oil injector sucks bad.. dump it
Old Mar 1, 2007 | 05:09 PM
  #16
yeah i am dumping the oil injection just drop the quad off at a shop they said sounds like piston slap is my noise but they are going to tear it down to deffntly make sure how does a piston slap i thought it would just stop running if that was happening or blow up can someone explaine thanks for all the help
Old Mar 1, 2007 | 09:55 PM
  #17
Dunedog805's Avatar
Piston slap happens when the piston is loose in the cylinder. usually its caused by worn rings or piston or the cylinder or a combo of all of them but u usually feel a power loss! and it "the noise"sounds like its coming from the top end at least from my experience i could be wrong?
becareful where u take ur bike to be fixed if u dont know whats going on they might try to bend u over! always ask for the old parts they replaced.
Ahtatu
Sep 28, 2015 12:14 PM
01ssls1
Sep 22, 2015 06:50 AM
merryman
Sep 19, 2015 03:15 AM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
