clutch handle
Old Feb 27, 2007 | 07:27 PM
dirtyblaster's Avatar
Default clutch handle
wuts the best race clutch handle out there?, becuz i broke mine and i figured to get a race instead of stock clutch handle.
Old Feb 27, 2007 | 07:48 PM
anyone?
Old Feb 27, 2007 | 11:35 PM
Raptor450's Avatar
The new AFV clutch levers are supposed to be unbreakable and have a lifetime warranty. They bend backwards if you wreck, but Im sure if you land on them just right they will snap. The downside is theyre about $75. I have always went to the local ATV shop and bought whatever after market lever they had in stock, even a dirtbike handle will do. I buy the whole thing, lever and perch, so you know they match up. That factory clutch perch with the parking break is junk anyway.
Old Feb 28, 2007 | 08:49 PM
recon99's Avatar
I agree that ASV are probably the best ones out there. But just about anything will be better than the stock one. The 2 main things to focus on are the pivot point and adjustment. Definitely get one that has at least a brass bushing pivot point, a bearing pivot is even better though. And a must-have for the perch is a quick-adjust system, they're so much nicer than the stock setup that uses a jam nut to keep it locked in place. I just have a cheap $30 set on my warrior and it's a big step up from the stock system and looks a lot better too.
lonerider856
Oct 13, 2023 03:45 PM
Ryan Silvani
Sep 19, 2015 09:53 PM
Lou Domenech
Sep 11, 2015 06:35 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
