warrior torque specs
Old Mar 23, 2007 | 01:12 AM
avenged10x's Avatar
Default warrior torque specs
Anyone know the torque for the head bolts on a warrior? I also have a rear brake problem. I was going to change the rear brake pads. I got the old ones off and put the new pads in the caliper. but when i try to slide the caliper over the rotar there isnt enough room between the caliper mounting bracket and the outside brake pad. I know that the piston is all the way in and the parking brake has been removed.
Old Mar 23, 2007 | 01:27 AM
2Owanage's Avatar
Wrong pads?
Old Mar 23, 2007 | 08:35 AM
MYRAPTOR's Avatar
I asked the same question about the head tensions and was told 29 lb on the four head bolts and 14 lb on the two hex head bolts.
Old Mar 23, 2007 | 09:22 AM
lucasislight's Avatar
i just changed my rear brake pads last night, no problems at all. as long as the piston is in and the pads are seated correctly they should fit. maybe they are the wrong pads like 2Owanage said. make sure they are seated at the back of the pad where the bolts go through them. use a flathead screwdriver and use leverage to get them to sit properly, this set i just got were a tight fit.
Old Mar 23, 2007 | 11:00 PM
Raptor450's Avatar
Ive had the same problem with new pads before. One time I used an old one and a new one for a day to wear the new one down enough for the other new one to fit. Then another time I kept playing with it until I got them on. I think I was trying to slide them over a section of my disk that was bent a little.
dannytas
Sep 26, 2017 06:31 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
raman8tor
Sep 20, 2015 07:35 AM
