Warrior rev limiter.
Old Mar 29, 2007 | 12:47 AM
Warriorider350's Avatar
Default Warrior rev limiter.
Does my 2001 warrior have a stock rev limiter. Will it hurt that machine if i keep it pinned in 6th reved out. im always worried about that and Ive never reved it for to long cuz im afraid it will blow up. and i dont think i have ever hit a limiter.
Old Mar 29, 2007 | 05:54 PM
Raptor450's Avatar
I dont think a Warrior has a rev limiter. I have revved mine wide open in neutral before and it sounded like it was cutting out. It may have just been about to blow up! You can hold it wide open in 6th gear and it will never hit any kind of limiter. You wont blow it up, either, unless the engine is low in oil or your carb is running lean. I usually let off the throttle and get back on it after about a 1/4 mile just to give it a break.
Old Mar 29, 2007 | 07:26 PM
ok thanks. i just wasnt sure because when u pin it in 6th it does sound like its revving really high and you feel the increase in vibration. I just dont want to damage the engine.
Old Mar 29, 2007 | 07:59 PM
54warrior's Avatar
I believe there is a limiter, you will float the valves first (bad) before you hit the limiter though.
Old Mar 29, 2007 | 11:30 PM
oh ok. so basicallyu the limiter on that machine is useless anyway. Its not like it is protecting the motor then anyway. thanx
Old Apr 1, 2007 | 01:22 PM
recon99's Avatar
No, there is absolutely no rev limiter at all on the warrior, it's not built into the cdi's circuitry. When the valves float you know to let off.
It's not good for any engine to be held pinned at peak rpms for any duration, it wears everything out real quick. Ever wonder why a race car engine gets rebuilt after a 300 mile race? If you want to go fast for longer periods of time, gear it higher so you're not revving it out so high.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
