Has anyone tried the fuel map adjustment for the 700 Grizz
I found this on on another forum,has anyone tried it and does it work, if you have any suggestions how amount of fuel to use.
Here are step by step instructions to program your stock Grizzly 700.
1. With the key in the off position, Hold "Select" & "Reset" and while holding them down turn the key on. The "d IAG" screen will pop up in 5-10 seconds.
2. Press the Select button to get it to the "Co" screen.
3. Hold "Select" & "Reset" again to get the "C1" screen to pop up.
4. Press "Select" & "Reset" again.
5. Press "Select" to raise the number and press "Reset" to lower the number.
6. Turn the key off to reset to the new settings.
7. Restart Quad
The number you find works best may be different from the number that works best for someone else.
7. Restart Quad
bpegram84
07-22-2015 08:15 AM
