stupid gasket please replie ASAP
no it did not come witha gasket it had silcone when i bought it from the dealer. the guy said the preveious owner is an idiot because he did not rejet the carb, and he tried to run it on unleaded and it was suppose to run on race gas. but this quad is in good shape, it was sitting in a garage for a year and half then finnaly he got gave it to the dealer where i bought it from. the dealer was totally honest with me he also told me the piston was not the right size but he sold me the quad for 2,100, the did me a free favor by rejeting got new tires for it and cleaned the whole engine and helped me get the wiseco piston for cheap. is that gasket called a O-ring?
if your going to use silicon, you need to remove the pipe and run a bead of silicon between the pipe and the motor, where the gasket should be, thus creating a seal. running a bead on the outside after its all bolted on is a waste of time and should be used as a temporary fix if need be.
jrooker6
04-23-2016 07:36 PM
1ArmBandit
55
10-14-2015 09:03 PM
Ricardo Covarrubias
09-17-2015 08:28 AM
slowgsxr97
09-08-2015 07:33 PM
