warrior direct shifter
Old Apr 1, 2007 | 08:23 PM
lucasislight's Avatar
Default warrior direct shifter
will a 400 ex shifter bolt onto the shiftshaft without bending, or does it need to be bent to clear the stator cover?
Old Apr 2, 2007 | 01:22 PM
54warrior's Avatar
I'm fairly certain that most any shifter you get will need bent to clear.
Look at this:
My Direct Shifter Picture
Old Apr 2, 2007 | 05:13 PM
is that a warrior shifter with a clamp welded on? i got a 400ex shifter for free today, so i will have to bend it when i get it, not a big deal. although i heard a yz250 shifter will clear the case without modification.
my next question is: should i re-temper the shifter after its bent (if it is even possible to re-temper)? bending will only weaken the ex shifter. i am pretty harsh on my machine and dont want the shifter to bend from abuse.
Old Apr 2, 2007 | 08:38 PM
Warriorider350's Avatar
Just a question. what purpose does changing it to a direct shifter serve.
Old Apr 2, 2007 | 09:07 PM
the stock shifter has this poorly designed linkage involved in it, the linkage can break at inoppurtune times like on a ride, and then you are stuck in whatever gear you were in when you broke. making it direct to the shiftshaft eliminates all that linkage and the chance of breaking.
Old Apr 3, 2007 | 08:49 AM
54warrior's Avatar
Yes, that is the stock shifter. It was cut and the clamp rewelded to it, then I heated it with a torch and bent it in the shape I needed. It hasn't bent at all since. This mod was performed probably 7 years ago. I wouldn't worry about the temper of the steel.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Whitelx1
Oct 2, 2015 10:55 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
