How to? hp in a warrior
Old Apr 3, 2007 | 11:38 PM
scoop06pv's Avatar
Default How to? hp in a warrior
Wat can i do to my warrior to make it a monster with horsepowerr?? thanks, John
Old Apr 4, 2007 | 02:45 AM
2FAST4URASS's Avatar
STROKE IT PUNCH IT AND PUT IN A GOOD CAM WITH GOOD DURATION.. then jet it well
Old Apr 4, 2007 | 07:25 PM
recon99's Avatar
There's tons of stuff you can do. If I were building one to be the fastest out there, i'd do a FST 446 kit, a Webcam .450 race cam with titanium valve springs, get bigger valves put in the head, and have the head ported by FST, Dynatek programmable CDI, Yoshimura slip-on and FMF Powerbomb header, Pro design intake, edelbrock carb, and if that's not enough power for you (you'll already be making 450 owners really really frustrated) spray it with a NX wet 20 shot. Of course that amount of power and torque on an otherwise stock warrior would be extremely dangerous and uncontrollable. You'd have to get extended a-arms and axle, probably a +2 swingarm, some good shocks, and some damn good tires and brakes to keep this monster under control.
Old Apr 4, 2007 | 07:49 PM
Raptor450's Avatar
Get rid of the Warrior and get a Raptor 700. The Warrior engine will never have "monstorous HP"[img]i/expressions/face-icon-small-smile.gif[/img]Unless someone comes out with a head that has 4 valves.
Old Apr 4, 2007 | 11:18 PM
ZapooMafoo's Avatar
wouldnt you overheat if you had a 446 kit in an air cooled warrior?
Old Apr 4, 2007 | 11:21 PM
recon99's Avatar
An oil cooler is all you need to keep it cool and reliable. There's 446 and 500 FST warriors out there that have been going for years and years on the orignal build.
Old Apr 4, 2007 | 11:27 PM
ZapooMafoo's Avatar
how do you get your warrior to be oil cooled (where do you get an oil cooler) [img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 4, 2007 | 11:44 PM
recon99's Avatar
There's a couple ways to do it, both involve tapping into an oil channel and routing the hot oil through a cooling elemnt mounted on the front of the machine. One method involves drilling and tapping fittings into the oil galley in the clutch cover, the other uses factory yamaha parts from a big bear, and bolts on in place of the stock oil filter cap.
Old Apr 4, 2007 | 11:45 PM
Raptor450's Avatar
Four Stroke Tech(fourstroketech.net) sells an oil cooler kit. You tap into the clutch cover and send the oil thru hoses to a little radiator. Theres also a way to install a Big Bear? (I think) oil cooler on a Warrior, but Im not familiar with those.
Old Apr 4, 2007 | 11:51 PM
Raptor450's Avatar
Seriously, do everything Recon said, which is about all you can do except put a rocket on it. Ive got almost all of those mods done to mine, and it still doesnt compare to 450s or Banshees when it comes to HP. I give the 450s a fit in a drag race, but they still beat me everytime.
