How to? hp in a warrior
Old Apr 9, 2007 | 09:56 PM
  #41
scoop06pv's Avatar
Default How to? hp in a warrior
thank you thats exactly wat i was looking for an explanation, to tell u the truth i am only 18 but i know an alright amount oabout engines... ido all my own work im even going to port and polish my own head and get bigger valves i love motors and i wasnt trying to be a dick either......so wat ur saying tho is i i could push more compression than i could use tht cam? or mayb one close to it with less overlap??? let me know im tryin my best to get the biggest gains with the lowest cha ching so im looking for small advantages.....if u have any trix or anything let me know im quite interested in learning,
thanks, John
Old Apr 9, 2007 | 10:29 PM
  #42
Jasonp's Avatar
thanks, John
Personally, I know alot about engines.. went to UTI hot rod U for training and I will not/did not consider screwing with my head. It's easier to screw something up then it is to make something right when porting heads. Warrior actually has a great flowing head. To put a bigger valve in you actually have to have the head machined.
If your trying to save money you could get the Wiesco piston and just have your cylinder honed out and then since you will have more static compression that big race cam will work much better.
http://www.popularhotrodding.com/tec.../velocity.html
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
