raptor 660 starter problem weird thing
Old Apr 15, 2007 | 07:21 PM
oberon1974's Avatar
Default raptor 660 starter problem weird thing
i know the starters suck, but have you ever heard of a starter continuing to turn over after hitting the button, even with the quad in gear and the clutch not engaged (the quads starter was driving the quad!) it eventually stopped on its own after maybe 10 seconds. there was no stopping it. this happened on the track, and was kind of embarrassing
Old Apr 16, 2007 | 01:05 AM
oberon1974's Avatar
come on guys someone has to know whats up here
Old Apr 16, 2007 | 01:26 AM
JonnyMack's Avatar
either your starter was sticking or your one way bearing went out--which is common on 660 raptors, if it's the one way get the L&A (may now be called L&L)--they won't fail again.....like the stock replacement will.....good luck
Old Apr 16, 2007 | 02:21 AM
bad350twin's Avatar
when i had my raptor, mine did the same thing. My problem was the battery relay was sticking! If it did it, i could tap the relay and it would stop!
Old Apr 16, 2007 | 01:15 PM
atvbandit's Avatar
The problem is caused by your starter solenoid sticking and this will damage your starter one way bearing, if hadn't already, so this needs to be corrected by replacement .
MikeyBoyesq
Nov 27, 2020 02:44 PM
sae156
1) Engine problems..
Jun 3, 2015 01:45 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
blaze_master
May 26, 2015 11:18 AM
RaptorGuy01
Oct 31, 2000 04:23 AM
