2007 yfz 450 running like crap????
Old Apr 16, 2007 | 02:14 PM
cheez4life's Avatar
Default 2007 yfz 450 running like crap????
acouple days ago my quad started to act up and i know it's still under warranty but i'd like to figure this out...... when i leave it sit overnight then fire it up and let it idle for a couple minutes to warm up i take off and it will run good for about two 100 yard runs back and forth.......then when i start to drive it after these runs it will bog out and not let me accelerate then if i pull the clutch in it will rev to high heaven but if i try to let the clutch out it will die and i can get it going again but with clutch in it will run great and in neutral....... any ideas stock quad........ tore carb apart 3 times now and can't find anything change plug too..... thanks alot joe
Old Apr 16, 2007 | 06:53 PM
yotatrailrunner's Avatar
sounds like a warrenty problem take it to the dealer.
Old Apr 16, 2007 | 07:17 PM
zizard's Avatar
sounds weird, man you should take it in,thats a new quad and lots of money.Let the warranty do tis job,might be something you'll never figure out
Old Apr 16, 2007 | 11:36 PM
Gruszka's Avatar
The parking brake?
njrider64
Jul 4, 2017 01:40 AM
Steven Bandemer
Jun 9, 2015 08:50 PM
blaze_master
May 26, 2015 11:18 AM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
