04' Bruin snapped bolt removing pull starter
Old Apr 26, 2007 | 11:18 PM
DBarkley's Avatar
Default 04' Bruin snapped bolt removing pull starter
I have some ticking noise going on in the upper part of the motor. Following the directions to adjust the valves, I snapped 2 out of 4 of the bolts that hold the pull starter on. I have not tried to remove the other two yet. I tried going forward and back on the bolts to loosen up the loctite on the bolts but before I knew it I snapped two of them. The remaining two I am going to try and heat. Question is how do I remove the snapped bolts. I am going to try and drill a hole through the middle and use an easy out. Has anyone had any success with this. Looking for any suggestions that I might try.
Old Apr 27, 2007 | 01:10 AM
quicksilver's Avatar
that's basically it, drill through the middle and use an easy out tool. they are probably installed with threadlocker, use some heat to loosen it up
merryman
Jun 15, 2015 02:36 AM
clsharky
Jun 8, 2015 11:38 AM
momofo
May 27, 2015 12:06 PM
Biggieshortie89
May 26, 2015 08:01 AM
jeffg
Oct 30, 2000 03:56 AM
