Replacement tire sizes for 07 Wolverine
I recently purchased a 07 Wolverine and I'm interested in finding some other tire for it that will give it a smoother ride with a lot less chop and bounce. The only tire I've found so far is a Mud Lite, but I don't really want such an aggressive tire. There seems to be a shortage of 23" tires that I can find in both a front tire and rear tire configuration to maintain the 4wd axle ratio between the front and rear. I like ITP Trac Stars, but they don't make it in a 23" and can't find it in a 22" in the front to match a 22" rear set. What have people used as a OEM replacement tire?
It's almost impossible to find 23's anywhere,I have a 03 wolverine and went 24's on the front and 25's on the rear..The Mudlites are lighter then most 6 ply tire,so you dont lose low end much at all,but they have a heavy tread..I can run my wolverine wide open on the road and cant tell them between the OEM that it came with,at lower speeds you can feel the tread a little but I would recommend the mudlites,in mud you cant beat them..But what ever you choose you will need to go 24's and 25's most likely ..
<div class="FTQUOTE"><begin quote>Originally posted by: toddmh
It's almost impossible to find 23's anywhere,I have a 03 wolverine and went 24's on the front and 25's on the rear..The Mudlites are lighter then most 6 ply tire,so you dont lose low end much at all,but they have a heavy tread..I can run my wolverine wide open on the road and cant tell them between the OEM that it came with,at lower speeds you can feel the tread a little but I would recommend the mudlites,in mud you cant beat them..But what ever you choose you will need to go 24's and 25's most likely ..</end quote></div>
I don't want to use a heavier or a larger tire size because a larger and/or heavier will more than likley lug the motor even more. I know a softer tire would help the ride in the rea a great deal because mine is very rough going over rocks and roots. I see there are a couple sport 4wd tires but they're all 25" or 26" tires. With as many tire manufacturers as there are, I can't believe there aren't more options in this size.
hehe looked at the swampfox they are golf cart tires lol..
I did not put them on the scale But I bet the mudlites weigh less then a brand new OEM,I can see what you are saying about size but..With mine I lost nothing in power(that I can tell)..I'm board so I will check around and see what I can find..BTW my 03 Wolverine is 100% OEM but the tires
here you go check these out..This is where I bought my tires,great store
http://www.4atvtires.com/tireSearch.php
<div class="FTQUOTE"><begin quote>Originally posted by: 07Wolvey450
swamp foxes are golf cart tires? theyr pretty good tires iv seen them on my buddies quad</end quote></div>
hehe after checking I see they make atv tires also,damn google search first 10 links were for golf cart tires lol
toonces
10-16-2019 12:11 PM
