Raptor 660 - Starter won't engage - just whirssss
Old 06-01-2007, 01:44 PM
RunAmuck69's Avatar
Default Raptor 660 - Starter won't engage - just whirssss
Went mudding and well it was doing it before, now that's all it does. Can push start it fine. Think the teeth on that there thing is gone... :/
What all do I need to replace and P/N if you have them?
Many Thanks!!!
Chris
Old 06-01-2007, 04:09 PM
ctateusa1's Avatar
yhea it sounds like the teeth are stripped off, but You should remove the starter to check first, you might just need a complete starter, or you might need the flywheel
Old 06-01-2007, 04:26 PM
RunAmuck69's Avatar
K thanks. What this I hear about a L/R or R/R starter instead of stock ?
Old 06-01-2007, 04:45 PM
garyc660R's Avatar
Have you ruled out a 1 way starter clutch problem?
Old 06-01-2007, 05:15 PM
RunAmuck69's Avatar
I have not - I was looking at the manual and not sure if I need to take the whole thing off (exhaust and all) or can I take the left side (AC Magneto side) inspection plate off to see the teeth? If not how to I check the starter clutch? I got'z the tools - just want to know what to take off in the best order to avoid a mess... [img]i/expressions/face-icon-small-wink.gif[/img]
Old 06-01-2007, 05:42 PM
garyc660R's Avatar
Do a search on Raptor 1 way starter clutch and you should find a ton of useful information....anywhere from symptoms to the actual fix. This has been a problem area on all of the early Raptors...although it seems like the last year or so of 660 production this problem did'nt seem to occur as frequent. You should quit running the engine if it's the 1 way....a spring inside the 1 way grenades and the spring winds up in your oil system.
Old 06-01-2007, 06:13 PM
RunAmuck69's Avatar
I took the gear cover off on the magneto side and the gears all appear like new. Guess I'll be tearing off the starter next... I took a pic but it appears you can't share those here.... booo hooo!
Old 06-01-2007, 06:25 PM
boooosh's Avatar
i have replaced my damn starter clutch 4 tims sense august.... dont know why but always goes bad.... i am almost certin thats your problem...
if you need one u can buy one from yamaha of troy on ebay i have delt with the several times they are good to there word
good luck
BoooosH
Old 06-01-2007, 07:19 PM
RunAmuck69's Avatar
How much did you pay vs a new starter RockyMountain has a new one for $165? I found this...http://www.raptorstarterclutch.com/ I assume the clutch is inside the starter?
Or there is this: <a target=_blank class=ftalternatingbarlinklarge href="http://cgi.ebay.com/ebaymotors/01-03-Yamaha-Raptor-660-ONE-WAY-BEARING-STARTER-CLUTCH_W0QQcmdZViewItemQQcategoryZ43977QQihZ010QQi temZ200115188350QQrdZ1QQsspagenameZWDVW
">http://cgi.ebay.com/ebaymotors...sspagenameZWDVW
</a>
So since I have the cover off - can I try to start it to see if the gear kicks out like it is trying to engage? If not what does that tell me? Clutch is bad or starter is bad or none of the above? Or do I just need to tear apart the starter to look inside? And this 52 tooth gear? Is that inside the starter or one of the gears I am looking at on the Magneto side?
Sorry kinda lost....
Old 06-02-2007, 12:11 AM
boooosh's Avatar
youve got the right part it is connected to the flywheel the raptorstarterclutch.com is a site telling you how to do the work its a great step by step...
it is all connected to the flywheel man not near the starter
good luck
Quick Reply: Raptor 660 - Starter won't engage - just whirssss
