Blaster won't shift
Old Jun 8, 2007 | 05:36 PM
dennisred69's Avatar
Default Blaster won't shift
If one of the cir-clips slide out of the grove then it will let your gears mesh together and will also cause this problem.
Old Jun 8, 2007 | 06:07 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Ok, had to do some research or the circlips but I think I figured out what your saying. Looks like they are in between the gears keeping them seperated. That makes since. Thanks that sounds like something to look for.
Old Jun 8, 2007 | 06:30 PM
JLsparky7's Avatar
Np, keep us posted.
Old Jun 9, 2007 | 12:15 AM
dirttamer85's Avatar
thats funny i dont no what the problem is but my buddy is going through the same thing right now. he just brought it in to some idiot but its been 4 weeks and the guy hasnt even looked at it 1
Old Jun 11, 2007 | 12:19 PM
  #15
Koopa's Avatar
Well guys, tore trans down this weekend. Shift arms look good, the rods were straight, and all the circlips were good. We found that the shifting rod was bent when we pulled it out so apparently its been stomped on pretty hard.
One other thing that surprised me was that my manual shows knocking out the trans with a rubber hammer from the back side but, the whole thing, shift drum and all just slid out before I knew what was going on. Should there be some kind of clip or something holding the shift drum in place? Is it possible that it's sliding around not allowing the shifting arms to slide correctly?
My uncle wants to buy a trans off ebay but I don't think there is any reason to. Everything seems to be checking out we just cant find the problem.
Old Oct 18, 2021 | 07:50 PM
  #16
Tobycakes's Avatar
Default change oil
[QUOTE=Koopa;2371886]I have a '98 blaster tore down in the garage. The clutch got to slipping on it and my 12 year old cousin started learning to ride on it. He did a lot of dry shifting and clutch popping, of course, trying to learn. Next thing we know it don't want to shift into 3rd. We pulled it in for tear down and could work with it and get into 3rd but it didn't want to come out.
So, now I have it all tore down and this is a first for me working on the transmission. The shifting forks seem to be good. Will I notice immediately if they are bent? Anyone have any suggestions as to what else could be wrong? Anything to point me in the right direction would help. Mine was doing the same thing. Changed from 80/90 weight to 10w 30 and it works great shifts all the way into 6 gear.
95wolv
Sep 27, 2024 12:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
Clint Russell
Sep 25, 2015 03:20 PM
BigCam
Sep 16, 2015 01:53 AM
nastyblaster100
Sep 13, 2015 01:19 PM
