HELP!! with a blaster
Old Jun 20, 2007 | 09:52 PM
suzukirider1992's Avatar
Default HELP!! with a blaster
Hi guys i just picked up a cheap blaster for my kid and it does not run it dosent seem like it has little compression, the carb is clean it has oil everything seems fine but i cant even push start it when u push start it goes to a low idol then shuts off. it is a 2003 blaster kick start it seems to have not alot of compression i have a compression tester but i dont know what it should be for normal compression PLEASE HELP MEEE all posts will be greatly appreciated thank you =]]]]
Old Jun 20, 2007 | 10:12 PM
Fulltiltrider's Avatar
What is the compression? should be around 170-180 i think.
Old Jun 21, 2007 | 03:47 PM
beaty's Avatar
i doubt its that high my banshees sopost to be like 140.........id imagine as long as its over 100 or 110 it should run or put ur finger on the hole if it blows it off u should be fine
Old Jun 22, 2007 | 03:08 AM
Yeh Im not real sure about blasters. My 250r had 170psi before I milled the head now its about 205psi RACE GAS ONLY
Old Jun 22, 2007 | 12:57 PM
JLsparky7's Avatar
If either one is less than 110psi or different from the other one more than 10% you wanna get them both honed. My cousin just got his cylinder back from this place. He dropped it off tuesday and had it at his door step thursday the same week. Excellent work and cheap as can be. check it out.
http://cgi.ebay.com/ebaymotors...temZ260129426706QQrdZ1
Old Jun 23, 2007 | 02:22 AM
avenged10x's Avatar
Change the spark plug and make shure you gap it correctly. My blaster goes through at least on plug a month. make sure its ngk too. They last the longest in 2-strokes. I That doesnt fix it also check the reed valves in the intake manifold. if they are broken, cracked, or just worn out it wont run.
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
