350 warrior lots of water has killed spark
buy a new spark plug. are you sure that all your connections are good, like the connection from the magneto to the spark plug cable? if changing your spark plug doesnt work, something is wrong with a connection somewhere. maybe the plug isnt being seated in the cable right. try putting some di-electric grease in there. just my 2 cents
Resolved-wiring harness where comes around frame to plug into CDI-- wrap rubbed through and one wire had small amount of insulation off-- when got wet arced out on frame--repaired and rewrapped entire wiring groups and taped a halfed piece of pipe insulation to frame to prevent in future--thanks for advice
