Front Tire Wobble
Old Jun 22, 2007 | 10:39 AM
cway77's Avatar
Default Front Tire Wobble
Hello,
I noticed I have what I am calling a wobble in my front rt. tire. This is something I noticed when I was checking all tires as I can just move the tire/rim back and forth and there is play in there where as the other side does not. Reminds me of the stupid snowmobile trailer bearings as this happened on that. Could this be the same type of problem with bearings?? Any ideas or suggestions on how to get this fixed would be much appreciated. Thanks.
Chad
01 Blaster
Old Jun 22, 2007 | 11:01 AM
Doctorturbo's Avatar
GOT BOOST!
<div class="FTQUOTE"><begin quote>Could this be the same type of problem with bearings?? Any ideas or suggestions on how to get this fixed would be much appreciated. </end quote></div>
Yep. I would take it apart and replace the bearings.
Old Jun 22, 2007 | 01:26 PM
cway77's Avatar
Any ideas what bearings it would be. I see there are quite a few different ones that could get rather expensive. Any chane you can look at them to see how damaged they are? What are things to look for with a damaged bearing? Thanks.
Old Jun 22, 2007 | 02:57 PM
lucasislight's Avatar
slop in the wheel is a dead giveaway. the reason the wheel wobbles is because there is play between the inner and the outer bearing races. its a cheap and easy fix, i wouldnt get the cheap ones off ebay, but get a middle of the road bearing like pivot works or similar. bearings are a wear and tear item that need to be replaced every so often.
Old Jul 4, 2007 | 01:47 AM
willieb76's Avatar
I had that problem on my 99 big bear 4x4 the spline and hub were worn down, allowing the wheel to wobble.
Reactant
Mar 30, 2022 02:08 AM
baysport
Jul 23, 2015 11:37 AM
rcappie4
Jul 18, 2015 07:51 AM
JackTheKing
Jul 14, 2015 09:09 PM
tporath
Jul 11, 2015 12:31 PM
