IDK what is wrong with it???
Old Jun 23, 2007 | 09:51 AM
Blaster008's Avatar
Default IDK what is wrong with it???
I dont know what is wrong with my 2003 200 blaster. I just got it about 5 dayas ago and in the intake i found a 3inch bolt so i took it out and noticed that it broke the reeds. I also Tryed to put a new spark plug in it and it still wont start. Also i did a compression check and it was about 130, And i checked the carb and it looked like it came off a brand new quad. If anyone commwnts my topic i highly thank you.
Kyle,
Old Jun 24, 2007 | 04:41 PM
TETuning's Avatar
Check for spark. Drain any old fuel and put in new stuff. Clear out all fuel lines and petcock. Remove and clean carb fully.
2 strokes are pretty simple. Not many things to go wrong, easy to diagnose.
Old Jun 24, 2007 | 04:53 PM
Williebee's Avatar
Yes and if the bolt broke the reeds you'll need to replace them also , and try to find out where the bolt came from in the first place ; sound's weird to me at the least ! Anyhow i hope you get it going again , and doesn't cost you an arm and leg to fix it ! williebee
Old Jun 25, 2007 | 08:38 AM
Blaster008's Avatar
Heyy, Thanks alot but i changed the reeeds im actually going out now to drop it off at a shop. Im done working with it. Its a cheap quad anyway if i cant get it running im going to sell it and get like a Z400 there sweety but anyway thanks again and good luck to u 2.
Old Jun 25, 2007 | 12:51 PM
TETuning's Avatar
Don't underestimate the Blaster, it's got plenty of potential.
Unless you're not mechanically inclined, just take some time to clean and inspect a few parts. The 2 stroke should run if the fuel lines are clear, carb is clean, and it gets spark. That's all there is to it.
Old Jun 25, 2007 | 08:36 PM
mdebuck's Avatar
y get a z400 when they cost so much to repair 4 strokes cost almost double to repair than a 2stroke just think about that for a while and also if you do sell it how much heck if your gunna just leave and not try then i sure will
bmxatv10
Oct 14, 2022 06:23 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
cboler9
Sep 24, 2015 08:35 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
