new member needs help with piston size
Old Sep 9, 2007 | 11:15 PM
rogers8945's Avatar
Default new member needs help with piston size
can i install a 98mm piston in a 600 grizz by boring or do i have to resleave. same qustion with a 101mm any advise would be much appreciated
Old Sep 9, 2007 | 11:36 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
you'd need to resleeve if u wanted to run a 98mm piston, you MAY be able to bore to 101 but would probably need to resleeve it.
Old Sep 9, 2007 | 11:42 PM
rogers8945's Avatar
i thought the 101 was bigger than the 98 but when i resleave is that all i have to do to it to be able to run it
Old Sep 9, 2007 | 11:43 PM
Speedy2222's Avatar
i don't know man... y do you even want to do that?
Old Sep 9, 2007 | 11:46 PM
rogers8945's Avatar
because i just bought it and it has some prety nasty goughes in it
Old Sep 9, 2007 | 11:48 PM
Speedy2222's Avatar
ah, you should be able to bore it out 1mm to 101 and install the 101mm piston
Old Sep 9, 2007 | 11:53 PM
rogers8945's Avatar
101mm is 6mm over stock bore im sorry im being such a pain but i want to make sure before i buy all this stuff i really apreciate the advice
Old Sep 10, 2007 | 12:02 AM
Speedy2222's Avatar
WHOPS i thought u put 660 grizzly.. just reread it and it said 600..
01ssls1
Sep 22, 2015 06:50 AM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
Bigtwin700
Sep 9, 2015 09:32 AM
atvcollector
Sep 8, 2015 05:11 PM
